Home Phone
REPETITIVE LAND LINE FAULT
SAYERS
Message 42 of 42
My land line has been repeatedly going dead for days at a time and then live again for brief periods, then dead again. This has been going on for just over six months now. Whilst I file a fault report each time and that fault is seemingly put right, within days however my land line is dead again - as it is as type this post.
Tests show that the fault is an external one, off my property.
My internet connection works fine during this time.
I'm going round in circles with this and would like someone to investigate and locate the problem and make a permanent repair. Can any one help?
After posting I thought I should add that when I mean my land line is 'dead' I mean there is no dial-tone, I can not ring out, nor can I receive calls. I lift the receiver and there is simply silence.
Cheers
41 REPLIES 41
Message 1 of 42
Hi Bully685@#
I'm sorry to hear this. Please can you create your own topic and we can look into this further for you.
Bully685@#
Message 2 of 42
Constant interference on the phone
Message 3 of 42
Hi woodstock4
Please can you create a new thread here Home Phone - TalkTalk Help & Support
We can then take a look at this for you.
woodstock4
Message 4 of 42
16/05/2024......    I reported a fault on my Land Line originally on 25/04/2024 and the fault has NOT been fixed. The problem is :- " I can make out going calls but not receive in coming calls " I have been promised an engineer ( Outreach ? ) several times to look into this problem but no engineer has been in contact. I need to speak to a human and not a machine.
Please contact me, I have been going round in circles with no sign of TalkTalk fixing my problem. If TalkTalk cannot correct the fault I will be forced to change to a different supplier. David
Message 5 of 42
I'm really glad to hear that the speeds have remained consistent 🙂 Please let us know if you need any further assistance 🙂
Thanks 🙂
Message 6 of 42
Good morning Michelle
After the land line fault was sorted and DLM optimisation carried out everything now seems fine. My speeds have levelled out and are certainly better than they were. Also, I notice I'm no longer getting the orange tab 'Server Unavailable'.
Thank you.
Message 7 of 42
Just checking back in to see how you've found the connection/speed over the last week?
Thanks 🙂
Message 8 of 42
OK, I've restarted the DLM optimisation process and your sync speed is now much higher. DLM will monitor for disconnections and errors over the next few days and will adjust the speed to maintain a fast but stable connection with a low error count
Message 9 of 42
Yes please, go ahead and reset DLM now.
Tony
Message 10 of 42
Hi Tony,
Thanks for the update. I can restart the DLM optimisation process, this should result in faster speeds but the connection may be a little unstable for a day or two, do you want me to reset DLM now?
Message 11 of 42
Morning Chris
You asked for an up date.
The Outreach engineer arrived just turned 8 this morning . Fault found up the pole. Land line working fine again now, Broadband okay, speed just a touch bit slow both up and down.
Cheers
Tony
Message 12 of 42
It's both internal and external, so they be able to check the line, cab etc
Message 13 of 42
A silly question.
Is the Engineer you've booked for someone who works on internal equipment only, or both internal and external. Just wondered just in case the fault turns out to be on external equipment rather than in my property, up a pole for example.
Tony
Message 14 of 42
Message 15 of 42
Many thanks. I'll report back after the visit.
Tony
Message 16 of 42
I've booked the appointment for tomorrow morning - August 04 2023, AM (8am-1pm) - please let us know how you get on
Message 17 of 42
Cheers
Tony
Message 18 of 42
OK thanks. I'll book the engineer and get back to you with the details
Message 19 of 42
Hello Chris
Yes, I accept potential engineer charges. I am available for  the visit at any time on any day.  I have been without a land line for 6 days now (I do not use mobile) and wish it resolved ASAP.
Tony
Message 20 of 42
Hi Tony,
Thanks for answering the security questions. Can you just confirm that you accept potential engineer charges and let us know when you can be available for  the visit
Anonymous User
