28-07-2023 12:41 PM - edited 28-07-2023 04:36 PM
My land line has been repeatedly going dead for days at a time and then live again for brief periods, then dead again. This has been going on for just over six months now. Whilst I file a fault report each time and that fault is seemingly put right, within days however my land line is dead again - as it is as type this post.
Tests show that the fault is an external one, off my property.
My internet connection works fine during this time.
I'm going round in circles with this and would like someone to investigate and locate the problem and make a permanent repair. Can any one help?
After posting I thought I should add that when I mean my land line is 'dead' I mean there is no dial-tone, I can not ring out, nor can I receive calls. I lift the receiver and there is simply silence.
Cheers
on 01-08-2023 10:39 AM
HI Tony
I've sent the message now. You should see this if you click on your Community Username/avatar at the top right hand corner of the community.
on 01-08-2023 10:37 AM
Okay. I'll watch for your private email message.
Tony
on 01-08-2023 10:32 AM
Hi Tony
Thanks for confirming. I'm just sending you a Private Message to confirm some details so we can arrange an Openreach engineer visit.
on 01-08-2023 10:30 AM
Hello Debbie
Yes, I removed the router, leaving just a phone plugged in the test socket for your test.
There is still no dial tone with either of the two handsets at the test socket, with router removed.
Cheers
Tony
on 01-08-2023 10:06 AM
Hi Tony
Apologies, did you see my last message? Was the router also removed from the line?
If the no dialtone fault is still present with 2 different phones at the test socket (router removed) then we will need to arrange an engineer visit to the property.
on 01-08-2023 10:03 AM
Hello Debbie
How are things progressing? Where you able to carryout the tests?
Cheers
Tony
on 01-08-2023 08:54 AM
Hi SAYERS
Has the router also been removed?
on 01-08-2023 08:52 AM
I have swapped over, the other handset is now plugged in.
Unfortunately I do not have another microfilter.
on 01-08-2023 08:49 AM
Hi Tony
Would it be ok to try the below just for 15 minutes so we can run the tests? You can then re connect the router again?
The same fault has been detected, would it be ok to swap over the handsets so I can run another test?
Do you have a different microfilter?
on 01-08-2023 08:48 AM
Correction, just in case it makes a difference. One handset is now plugged into the test socket via a phone/router splitter. If I plug the phone into the test socket alone then I will loose my internet connection and we won't be able to communicate.
on 01-08-2023 08:45 AM
Hi Tony
Thank you. The same fault has been detected, would it be ok to swap over the handsets so I can run another test?
on 01-08-2023 08:42 AM
One handset is now plugged into the test socket.
on 01-08-2023 08:32 AM
Hi Tony
Please can you try connecting one handset at the test socket?
on 01-08-2023 08:30 AM
Hello Debbie
In answer to your question, a phone is not currently connected at the test socket. My phone is currently connected in the normal socket.
Would you like me to plug my phone into the test socket or should I leave the phone connected in the normal socket?
I have two traditional handsets available. The line is dead with either set plugged in to either socket.
Cheers
Tony (Sayers)
on 01-08-2023 06:52 AM
Hi Tony
The line test is detecting a loop fault and this is often caused by internal wiring or equipment connected to the line.
Just to confirm, is the phone currently connected at the test socket?
on 31-07-2023 07:30 PM
I have similarly found Talktalk's My Connection checks to be unreliable.
They fall off regardless of whether anything has been done or not.
Staff will be back during the day to follow up, @SAYERS.
on 31-07-2023 06:43 PM
There has been no change, my land line is still dead (silent, no ring tone ) as of 18.40 this evening, five continuous days - I still can not make nor receive any calls. I should add I am unable to make 999 calls if I was to need to do so and I can not use telephone banking on which I rely.
After making a fault report on the 26th July I have monitored Talktalk's 'Track My Fault' and both it and a subsequent report, have been 'deleted'. I am on my third fault report for this current issue.
Cheers
Tony
on 31-07-2023 09:23 AM
Hi SAYERS,
I'm sorry to hear that you're experiencing problems with your service. How has it been since your last post?
on 29-07-2023 02:51 PM
Hi @SAYERS your post has been escalated and you should hear Monday. In the meantime please add your landline phone number to your community profile so that your account can be identified by the team here.
https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personalinfo
