Home Phone
Telephone Settings issues since upgrade to Full Fibre
aa2000
Enlightened One
Message 28 of 28
I upgraded from Fibre 65 to Full Fibre 65 on 05 September 2024.
Since the upgrade I find that my 'Withhold Number' setting in My Account has switched itself over to the number being withheld.   I have today twice unticked this option, but the tick just keeps returning.   I DO want people I call to be able to see my number.
Also, my preferred 'Mobile Bar' option has always been set to bar calls to Mobiles. Since my upgrade, the check box has a tick in it, but I find I am still able to call Mobile numbers.
Would be grateful for help in sorting these issues.
27 REPLIES 27
Message 21 of 28
HI @aa2000
There is an know issue with My Account features now showing, its been raised previously sorry.
I will remove the withheld number,  We will need to remove and re-add the mobile bar to reactivate it, there is a chance with the switch to VoIP its not carried over.
Any auto email can be ignored.
Message 22 of 28
I re-escalated it on the 8th, but as you posted after that, it may have pushed it back.
The new thread will be removed.
Please only follow up on this one, @aa2000.
Wait for staff to reach it again, rather than posting, or the same thing will happen!
Message 23 of 28
Is there any update on these issues please, my thread was missed yesterday and today?
Many thanks.
aa2000
Enlightened One
Message 24 of 28
Hi OCE's
Following my upgrade to Full Fibre 65 VOIP on 5th of September,  I am still experiencing issues with my 'Telephone Settings' in 'My Account'.   The list of choices has shrunk from what it was prior to my FF upgrade and I find I am unable to make any changes.  When I try to change options, I immediately receive an email confirming the change(s) have been made, but when I check back after 2 hours, the options remain unchanged and the changes are NOT actually made.  Have tried a few times on both my 'Brave' and my 'Edge' browsers with the same results.
Currently my phone number is Withheld, but I actually DO want people I call to see my number.  Also my calls to Mobiles are barred and the 'Mobile Bar' option is one of the number of options that have now disappeared from the list.
So, I would be grateful if the following could be restored:
  1. The FULL list of Telephone Settings options, including 'Mobile Bar'.
  2. The ability to select and deselect preferred options and have those choices saved.
Thanks a lot.
Message 25 of 28
Thanks for the update. Once an option is selected then it can take up to 2hrs to take effect. We'll check back in with you on Monday to see how you're getting on.
Message 26 of 28
Hi @Anonymous
I usually use Brave browser without problem.   I have just logged into my Account using Edge and have unticked the 'Withhold Number' checkbox.  I got a message that no other change requests would be permitted for 2 hours.  I just tried to make an outgoing call though and my number was shown as 'Private Number'  and I WAS able to dial my Mobile despite the tick in the Mobile Bar checkbox.
Message 27 of 28
Good afternoon,
I'm sorry to hear this. Have you tried using a different browser?
