Home Phone
What phone cable is needed for the microfilter
Renniks
Message 23 of 23
Hello everyone
I need to move my phone elsewhere and I've bought a new lead. However when I plug in the new lead the phone rings but you cannot hear anything when you pick it up? It works perfectly once I put the old one in. I am using the D-Link microfilter that comes with the service.
Tia
Lee
22 REPLIES 22
Message 1 of 23
You're Welcome 🙂
Message 2 of 23
Thanks to Chris and yourself for the help
Cheers
Lee
Message 3 of 23
yes, should arrive in a couple of days.
Message 4 of 23
Hi Karl
Thanks very much
So I will get it in a few days?
Cheers
Lee
Message 5 of 23
Microfilter dispatched.
Message 6 of 23
My information has been updated
Thanks for the help
Cheers
Message 7 of 23
Can you update your community profile to include your:
  • Name
  • Telephone number
  • Alternative contact number
We'll then arrange to send the micro-filter. Please do not post this information on this thread. Once you've updated your profile please post in your topic to confirm it's updated.
Message 8 of 23
I'm sorry, we don't have longer router cables but I'll order another micro-filter
Message 9 of 23
Yes please, I am corresponding with you for my partner as she doesn't understand all this type of stuff. Is there anyway you could send a longer router cable also?
Message 10 of 23
I can send a micro-filter, would you like me to arrange this?
Message 11 of 23
Hi Chris,
Can you recommend one to me?
Message 12 of 23
Thanks for the information. In answer to your question, no they would be the same at both ends. I think we should try a different micro-filter, would you like me to send one?
Message 13 of 23
PS
The cable I have had for ages is 4 pin.
Can you get 4 pin phone socket end and 2 pin on the end that connects into the phone?
Message 14 of 23
Hi Chris
The 2 pin worked connected straight to the phone socket (no microfilter) but the 4 pin lead didn't work through the microfilter.
Cheers
Lee
Message 15 of 23
Ok thanks, so just to confirm which one of the longer cables worked when connected directly to the socket, or did both the two and four pin cables work?
Message 16 of 23
Hi Chris
Yes it did work directly without the microfilter, I did think it may be the culprit to be honest. If I get a new one I would still need a longer lead for the router also it's the small square plug either end, can you recommend them to me?
Lee
Message 17 of 23
OK thanks, do either of the cables work if you connect directly to the wall socket without the micro-filter?
Message 18 of 23
Hi Chris
4 pin on both ends. The one I bought was 4 pin both ends, once attached the phone would ring but no dial tone and you cannot here the person on the other end
Here is the lead I bought
ASNQ BT Telephone to RJ11 Cable Long 3m - BT cable 4 Pin Wire 6P4C ADSL Modem Phone Plug Male Broadband Cable, Extension Lead for Landline, Modem, Fax, Dial-up White https://amzn.eu/d/b2rNVKS
Cheers
Lee
Message 19 of 23
Hi Lee,
How many pins are in the cable that works?
Renniks
Message 20 of 23
Hi Debbie
I have tried 2 cables
Phone end 4 pin into the microfilter smaller 4 pin plug into the phone
Also same cable but 2 pin either end
The fone rings but there is no dial tone and you cannot hear anyone on the line
I am using a D-Link microfilter that came from talk talk
Any help is appreciated
Lee
Anonymous User
