on 04-02-2025 09:46 AM
Hi, People (calling me) have reported they are having issues when calling me - they have to keep trying to eventual get connected.
on 19-02-2025 06:31 AM
Thanks for the update and please let us know if you do experience any further issues.
on 18-02-2025 02:43 PM
Hi. The engineer had to replace some of the cabling. Thanks for your help. Thanks.
on 18-02-2025 07:24 AM
on 12-02-2025 08:03 AM
Hi @shodges
I've checked and I can see that they have the correct mobile number (showing on your account)
on 12-02-2025 07:53 AM
Thank you for your help. Can you please ask them to call the mobile number associated with the account (my daughter) otherwise there won't be access to the property due to accessibility issues. Thanks again.
on 12-02-2025 07:18 AM
Hi @shodges
Sorry for the delay.
I have arranged the engineer visit for 17/02 PM (1pm - 6pm) I have requested that they call 30 minutes before arrival however this is not guaranteed.
If you need to reschedule, please let us know at least 24hrs beforehand. If you call up to rearrange the appointment you will just need to provide your name and landline number, the appointment will show on your account.
on 11-02-2025 12:06 PM
Hi.
13th Feb - AM
17th Feb - PM
Would need a ring 30 mins before arrival.
Will I get a ref number in case I need to rearrange.....
on 11-02-2025 11:13 AM
Hi @shodges
Please can you provide your availability AM and PM and I will arrange the first available appointment.
In regards to potential engineer charges, more information can be found here Engineer charges
As the line test is still detecting a potential fault with everything removed (including faceplate) this helps to rule out your own equipment or internal wiring.
Yes you can re connect your face plate again now.
on 11-02-2025 11:11 AM
I assume I can now put the faceplate back in place? Regards.
on 11-02-2025 11:10 AM
Hi. Yes please. Is there a cost? Also need to confirm time - date / availablity etc... thanks.
on 11-02-2025 11:07 AM
Hi @shodges
As the line test is still detecting a potential fault with everything removed then I think we should arrange an engineer visit (Openreach)
Would you like me to arrange this for you?
on 11-02-2025 11:06 AM
Have previously posted pics. There are no wires to the faceplate it looks like an extension to the test socket.
on 11-02-2025 11:04 AM
Hi. Yes face plate is removed, microfilter was previously plugged into the test socket - now removed pending your additional tests.
on 11-02-2025 11:01 AM
on 11-02-2025 10:58 AM
Hi. Try now. I've removed everything (microfilter) from the test socket
on 11-02-2025 10:56 AM
Hi. Try now
on 11-02-2025 10:46 AM
on 11-02-2025 09:58 AM
Hi, thanks. I will when they contact me to confirm their availability as I'll be without a phone/connectivity otherwise.
on 11-02-2025 09:56 AM
Give @Anonymous or @Debbie-TalkTalk a period of time today when ALL equipment is removed from the test socket. They need a full 30 minutes for this, as detailed in the last staff reply, @shodges.
