on 04-02-2025 09:46 AM
Hi, People (calling me) have reported they are having issues when calling me - they have to keep trying to eventual get connected.
on 10-02-2025 08:00 AM
Good morning @shodges
Thank you for re-connecting back at the test socket. I've re-run the line test now which is still detecting a loop fault. Would it be possible to remove all the equipment from the line at some point today for 30 minutes (between now and 2pm) so we can run the line test with no equipment connected to the line please?
on 09-02-2025 11:52 AM
I've attached the microfilter to the test socket. There were no wires on the faceplate. See attached pictures.
on 08-02-2025 06:43 PM
please see photos
on 08-02-2025 05:07 PM
Leave it as requested by staff, @shodges, not back to normal.
There are other tests they will need to run in that set up and it's better if you don't switch it around meanwhile as this will start to affect your line speed if you do it too much.
It will get misdiagnosed as disconnections and dynamic line management will try to modify your speeds to stop that happening.
So set it up just one more time at the test socket and leave it there for staff to run their own tests. They may well run them before breakfast time, Monday.
on 08-02-2025 03:51 PM
Hi. I removed the face plate and connected the micro filter, however the phone issues continued. I've attached a photo. I've since put the face plate back in place.
on 08-02-2025 02:26 PM
Leave it set up at the test socket until staff tell you otherwise, @shodges.
They are not on here at weekends. Keep an eye out for replies during the day [Monday to Friday].
on 08-02-2025 01:17 PM
Hi, once it's connected to the test socket what's next?
on 06-02-2025 07:01 AM
Good morning,
This type of socket should have a test socket below the faceplate. Could you try gently removing the lower faceplate (there may be wires connected to the back of the faceplate) and then connect the microfilter, router and phone to the test socket please.
on 05-02-2025 08:56 PM
Staff will respond in the morning, @shodges.
on 05-02-2025 08:02 PM
Ive attached a pic - can you advise whats next please.
on 05-02-2025 08:00 PM
Please see attached
on 04-02-2025 10:55 AM
Hi @shodges
If you contact our Future Fibre team they can take a look if FTTP is available in your area. The contact details are on the help page below.
on 04-02-2025 10:52 AM
Hi - Would it be an option to move to voip (over my fibre) as aware the copper service is due to end shortly.
on 04-02-2025 10:00 AM
on 04-02-2025 09:57 AM
Hi - The landline (phone) has always been connected to the main socket, ive tried a different handset but same issue - what do you mean by test socket?
Hi @shodges
Would it be possible to post a photo of your master socket on this thread so I can check if your master socket has a test socket?
on 04-02-2025 09:55 AM
The phone is connected to the main socket and has always been connected to the same (main) socket - what do you mean by test socket?
on 04-02-2025 09:53 AM
Hi @shodges
The line tests have detected a loop fault and this fault is often caused by internal wiring or equipment connected to the line.
Have you tested with the phone directly at the test socket?
