Home Phone
intermitent inbound call issues
shodges
Message 40 of 40
Hi, People (calling me) have reported they are having issues when calling me - they have to keep trying to eventual get connected.
S Hodges
39 REPLIES 39
Message 21 of 40
Sorry only just seen this msg. Let me know next steps.
S Hodges
Message 22 of 40
Good morning @shodges
Thank you for re-connecting back at the test socket. I've re-run the line test now which is still detecting a loop fault. Would it be possible to remove all the equipment from the line at some point today for 30 minutes (between now and 2pm) so we can run the line test with no equipment connected to the line please?
Message 23 of 40
I've attached the microfilter to the test socket. There were no wires on the faceplate. See attached pictures.
S Hodges
Message 24 of 40
please see photos
S Hodges
Message 25 of 40
Leave it as requested by staff, @shodges, not back to normal.
There are other tests they will need to run in that set up and it's better if you don't switch it around meanwhile as this will start to affect your line speed if you do it too much.
It will get misdiagnosed as disconnections and dynamic line management will try to modify your speeds to stop that happening.
So set it up just one more time at the test socket and leave it there for staff to run their own tests. They may well run them before breakfast time, Monday.
Message 26 of 40
Hi. I removed the face plate and connected the micro filter, however the phone issues continued. I've attached a photo. I've since put the face plate back in place.
S Hodges
Message 27 of 40
Leave it set up at the test socket until staff tell you otherwise, @shodges.
They are not on here at weekends. Keep an eye out for replies during the day [Monday to Friday].
Message 28 of 40
Hi, once it's connected to the test socket what's next?
S Hodges
Message 29 of 40
Good morning,
This type of socket should have a test socket below the faceplate. Could you try gently removing the lower faceplate (there may be wires connected to the back of the faceplate) and then connect the microfilter, router and phone to the test socket please.
Message 30 of 40
Staff will respond in the morning, @shodges.
Message 31 of 40
Ive attached a pic - can you advise whats next please.
S Hodges
Message 32 of 40
Please see attached
S Hodges
Message 33 of 40
Hi @shodges
If you contact our Future Fibre team they can take a look if FTTP is available in your area. The contact details are on the help page below.
Your Future Fibre Support Hub
Message 34 of 40
Hi - Would it be an option to move to voip (over my fibre) as aware the copper service is due to end shortly.
S Hodges
Message 35 of 40
Message 36 of 40
Hi - The landline (phone) has always been connected to the main socket, ive tried a different handset but same issue - what do you mean by test socket?
S Hodges
Message 37 of 40
Hi @shodges
Would it be possible to post a photo of your master socket on this thread so I can check if your master socket has a test socket?
Message 38 of 40
The phone is connected to the main socket and has always been connected to the same (main) socket - what do you mean by test socket?
S Hodges
Message 39 of 40
Hi @shodges
The line tests have detected a loop fault and this fault is often caused by internal wiring or equipment connected to the line.
Have you tested with the phone directly at the test socket?
