4K box can I receive UHD on this box
Geordyboy1
Message 2 of 2
can I view UHD films with 4k box  have
1 REPLY 1
kanya-TT
Message 1 of 2
Hey there, @Geordyboy1. Yes, you can view UHD films with the TalkTalk 4K TV Box. The box is designed to support 4K Ultra HD content, allowing you to enjoy films and shows in higher resolution, provided you have a compatible 4K TV and a suitable internet connection for streaming.
Make sure to check that the content you want to watch is available in UHD, as not all titles may be offered in that format. Additionally, ensure that your HDMI cables are rated for 4K to get the best viewing experience.
Kanya
