Apple TV
PeteFish
Message 4 of 4
How doI get Apple TV on my Huawei Talktalk Youview box?
3 REPLIES 3
Message 1 of 4
Apple tv is not available via the youview box.
Message 2 of 4
You can't, the app is not supported.
Message 3 of 4
You can't. Apps are preset by YouView and new apps only added if the App owner, in this case Apple, create a specific app that is compatible with older YouView boxes.
