2 hours ago
Lots of channels removed from guide. Can change manually. Says the channels are locked.
2 hours ago
I assume you have a Netgem box, if not please let us know which box you have.
I have been offering suggestions regarding issues with the Netgem box, but reported issues seem to be increasing, so don't want to waste your time with potential solutions that may not work.
I know these issues have been reported to Netgem and TalkTalk are awaiting a firmware update to apply to the boxes.
Staff are back on Monday and will hopefully be able to advise further then.
In the meantime I suggest you put the aerial in the TV and bypass the box and use your TV tuner if possible.
