Getting sky cinema
John9463
Message 3 of 3
Hi. I have a Talktalk tv package with Wi-Fi and telephone. I want to add Sky cinema, and access it on 2 tvs. One of my Sony Bravia smart tvs has the Now app, but one doesn’t, and I can’t find a way to add it. I understand that I need to take out a subscription directly with Now tv to get Sky cinema. If I sign up for a Now tv subscription can I only access Sky tv through the Now app, or will the appropriate Sky cinema channels go live on the channel guide?
Mandisa-TT
Message 1 of 3
Hi @John9463 with a NOW TV subscription, you will access Sky Cinema through the NOW TV app, and the channels will not be integrated into your regular TV guide. You can enjoy the content on both TVs by using the appropriate methods to access the NOW TV app. Now TV will be able to assist you.
Message 2 of 3
Now is not available via TV channels.
You need to use the Now app to access.
If your TV doesn't have it you should find a forum dedicated to the TV make to see if you can add it. If not the best bet is to buy an Amazon Fire stick and access via this.
