amazon Prime app will not load.
wJanet1
Message 31 of 31
Help Please, My Amazon Prime app will not load on Tv box, I'm using a DN372T set top box, all was ok until yesterday, tried to load it but just keeps going back to a tv channel I was watching. I've looked at all the possibilities, I've reset everything but still no joy, just need some help as want to watch my programmes. Thanks.
WJanet1
30 REPLIES 30
Gliwmaeden2
Message 1 of 31
@Gazzamagoo, I think the OP's issue was done and dusted a full month ago, so there's no point adding comments here.
In fact it can be irritating for a customer when they start getting notifications on their old thread for an issue long since concluded.
I'm closing the thread to new comments.
Message 2 of 31
Hi yer
It's a shame TT have moved away from the box in question, I found (still find 1 of em) perfect for my needs of recording/playback and fast forwarding through the adverts.
Some (especially here, on this site) will argue in favour of the new box (a 4k, non-recordable I believe) but I fer 1 see it as a step back.
wJanet1, may I ask if you went to SETTINGS on your TT box, and clicked SOFTWARE INFORMATION (down the bottom) then UPDATE APPS on the right hand side?. If not, would you mind giving it a shot, couldn't do any harm.
When I have, often, all I get is "We can't update your apps"  and I'm advised to "Please try again later, or try" yadi yadi yada.
Good luck, all the best
Sincerely
Message 3 of 31
Ok, but it was your last comment "SO here I am" that led me to believe you were looking for help.
Message 4 of 31
I wasn't looking for individual help, I was helping (I think) @wJanet1, by relating my own experience with the SAME App/issue, and (I suspect) the same TT box.
Message 5 of 31
@Gazzamagoo if you are seeking help that's how the forum works.
You won't receive individual help as this is @wJanet1 thread.
Message 6 of 31
Why would I want to start my own thread?
wJanet1 (the conversation Starter) has an issue, and I was simply posting an answer about that issue, as I have the very same problem ...with 1 of 2 identical TT youview boxes, simple as.
Message 7 of 31
@Gazzamagoo
Please start your own thread as each case is considered unique and it is easier for support to be given to one person per thread and also less confusing.
To start your thread click the Browse button, then Help With Your Service and select the appropriate category. You will then see a Blue Button "Start A Topic"
Please also note that you should only post back on that thread and not start another on the same topic as multiple posts cause delay to you and others seeking help.
Thank you
Gazzamagoo
Message 8 of 31
I have the same problem...on 1 of 2 of my (recordable DN372T 01.03.P) boxes.
2 of the same box
The 1st?
Will play ALL other Apps normally, but not (strangely) Amazon Prime, simply going back to the station it was on B4 Amazon Prime was selected, whereas the 2nd box plays ALL Apps, even Amazon Prime, without issue.
Going to Settings>Software Information of the problem box, I note the  "Last checked for updates" date is today, so I can't (it won't) update the (already said to be up to date) software, THEN when I try to update the Apps, it won't.
I'm told "We can't update your apps" and I'm advised to either "Please try again later" (as I've been told many times) and/or to "visit talktalk.co.uk/tvhelp for help" SO, here I am 😇
Message 9 of 31
Hi @wJanet1No problem. Thank you for the update.
wJanet1
Message 10 of 31
Hi fry8s,
Thanks for that, I'll see what the new box does, if no go I'll get a bt box.
wjanet1
wJanet1
Message 11 of 31
Hi SDuguid,
Thanks for your message, it is a pain, can you get prime on your other devices? computer/mobile phone etc, as I can and customer services had said they thought it could be the set top box, so they are sending me a new one. I'll post on here if it fixes the problem
wjanet1
wJanet1
Message 12 of 31
Hi frys8,
Thanks for your reply, yes I've done everything possible even a reset, so I got back onto customer service Saturday, the chap I spoke to said that there had no confirmation if amazon had been stopped, he thought that the box could be the problem as I could use it on my phone and laptop, aliso I  noticed that Netflix had disappeared, so he's sent me a new box so I'm hoping it will sort the problem.
wjanet1
Message 13 of 31
Good morning @SDuguid . Please start your own thread should you require assistance.
Message 14 of 31
Hi John. I agree with you. Why couldn’t they tell us things were changing? A heads-up would’ve been nice, giving us time to find replacements. Been trying to fix this issue for couple days only to find these posts explaining why it’s not working. 😞 Thank you for finding things out.
SDuguid
Message 15 of 31
Hi wJanet1. This is happening to me too! I haven’t been able to fix it yet, & I’ve done what you have. Will let you know if I do. If someone gets back to you with a fix, please keep me in the loop. It’s so frustrating.
Message 16 of 31
If you have tried resetting the box (if not I will post details later) and the app still doesn't work a couple of additional thoughts.
If you have a smart TV can you log into the app that way?
If not and the box works otherwise, I'd suggest buying an Amazon Fire stick or similar, that has the most up-to-date apps including Prime, and ITVX.
This does need your TV to have an HDMI Port on your TV and if you don't have a spare, you can purchase an HDMI splitter quite cheaply. Get one with automatic switching rather than one with manual buttons.
Hope this helps.
Here are the box reset instructions. If the box is working ok to record, I'd skip the last part as you would lose recordings. These boxes are though, approaching the end of the life.
Have you tried a soft reset? To do this hold the power button on the front for around 10 seconds and the box should restart.
If this doesn’t work then have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If all else fails then try a full factory reset from the settings menu you've just used above. You will lose your recordings but you may be asked to do this before the Support Staff look at other alternatives.
Message 17 of 31
I'm not surprised the app no longer works. Amazon updated the app a few years ago and it was no longer compatible with the older first generation YouView boxes.
If they have updated recently it's possible that the technology it uses renders it obsolete on 2nd gen boxes.
Note: this is nothing to do with TalkTalk terminating any contract if that's the case, it's down to the app owner, in this case Amazon, just like it was with Netflix and ITVX., and YouView who control the UI on the box.
What TalkTalk may have done is removed the ability for you to pay any subscription for Amazon via your monthly bill, but I thought that had long gone.
As for more recent boxes, it works or the Hub, but that does not record as @Gliwmaeden2 pointed out.
Your options for recording boxes are limited these days to the Manhattan T4R which utilises Freeview, and the EE / BT Pro box (which you can only buy on the grey market from CeX or eBay).
If you do purchase your own box, then phone the loyalty team and get the TV charge removed from your contract if you are paying this.
Message 18 of 31
You'd need to discuss the issue of a box via Chat any day, @wJanet1, or phone Monday to Saturday daytime, 03451 720088.
You'd need to negotiate them sending out the new TV hub, and noting it as a contractual change.
Ask them if you have to return the old TV box. Their more recent models don't have a recording facility.
@fr8ys can advise you further on this matter.
wJanet1
Message 19 of 31
I 've just been informed from another member that TalkTalk has ended its contract with Amazon so have deactivated the app, could you advise me of a more recent box that I can use that i can download the app onto.
wjanet1.
Message 20 of 31
Hi John,
Thanks for telling me, I've spent the last four days sorting this out with amazon and TalkTalk, cannot understand, they must have known that the contract had been terminated. Do you have any ideas what the most recent boxes I can use? I was wondering about getting a YouView box from BT I've had one before.
