DVD Player
IngridEdge
Message 2 of 2
Now I have the new box, I can't get my DVD player to connect to the TV, even though the cable goes directly from the DVD player to the TV and does not got through the box. Is this simply another something I've lost in the service of progress, or can I get it back?
1 REPLY 1
Message 1 of 2
Any device you connect directly to your TV will not be affected by your TalkTalk services or the new TV Box.  If connecting these items to the TV via HDMI cable, you may need to manually switch the source channel on the TV, most TV remotes will usually have a source button to switch inputs from HDMI1, HDMI2 etc.
