Got no bbc, itv, channel4/5
on 15-12-2024 02:05 PM
Message 3 of 3
Hi since the storm we’ve had no channels bbc1,2 channel4/5 just a blank screen? No sound either
Labels:
- Labels:
Channels
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
on 16-12-2024 08:38 AM
Message 1 of 3
Have you tried the aerial direct to your TV ?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 15-12-2024 04:43 PM
Message 2 of 3
Have you tried a retune? Pull the aerial out first then retune. You will get 0 channels but this will clear the box's memory. Reconnect the arial and tune again.
What happens if you put the aerial directly into your TV by passing the box? Do the channels play?
If not then it's possible your aerial has been damaged in the storm and mat needs realigning or changing. You will need to contact a local aerial installer if so
If the channels appear on the TV and a retune does not recover them, please let us know which box you have for further support.
Thank you.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
