How to delete a programme from the schedule on a 4K TV box?
trumpetman
Message 42 of 42
I have been supplied with a 4k TV Box and I hate it!
Amongst many other things it doesn't do, is that it seems impossible to delete a scheduled recording from the schedule once the series has been watched.
There has to be a way of doing this otherwise it will end up with many programmes that cannot be deleted.
If anyone has found a way of doing this, please, please let me know because (as they say) it is doing my head in!
Silver surfer but been using and messing about with computers since MS DOS 5
41 REPLIES 41
Message 41 of 42
I've responded under your other thread but here is the answer.
To delete recordings or schedules, go to the recordings tab across the top.
Select a recording and you then have the option to Play or Delete
Below this scheduled recordings are shown. Again select and there is an option to Modify. Click this and you can then delete the schedule.
