Live TV.....no vision or sound
on 04-08-2024 08:48 AM
Message 4 of 4
I recently installed a new TV Hub. It was working fine until today. I cannot get live TV...I get a blank screen and no sound. I have checked all the connections and they are good. The Apps are working as they should including, on BBC Iplayer, the live TV. Please advise. Thank you.
Labels:
- Labels:
Channels
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
3 REPLIES 3
on 04-08-2024 03:24 PM
Message 1 of 4
Pleased to hear you got it working.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 04-08-2024 02:47 PM
Message 2 of 4
The aerial is fine.
I turned the box off and on and the problem is resolved.
Thanks for prompt and helpful reply.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 04-08-2024 10:42 AM
Message 3 of 4
Do you get a picture on the TV if you plug the aerial directly into it?
If not then your aerial has failed and you will need to consult a local installer.
If yes, then remove the box from the mains and turn on again.
If still no picture, perform a retune with the aerial out to clear the memory, then replace the aerial and retune again.
If that does not work, then you will need to perform a reset of the box to factory settings from the settings menu.
Let us know how you get on.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
