MY STB Box
andyduudz
Message 3 of 3
hello everyone, just a quick query.  I dont have my TV on very much, and have been paying for this add on , the £5  STB box , which as google play ,store,  But while browsing i Noticed many of the apps  are mainly for  foreign stations, like in the entertainment, section  , and  they is no way !0000 google apps  on my stb box, , i was more happy with my other talktalk youview box,  ,it  records programmes , i am glad i kepted it and thinking of switching over, will i be able to cancel this add on,  good day all
amaaduudz
Message 1 of 3
thank you for responding. 👌
amaaduudz
Message 2 of 3
You will need to phone to cancel the TV subscription and arrange for the return of the TV Hub.
Regarding your old YouView box, you should be able to kerp this and continue using it, but be aware it has no ITVX or Netflix and now some customers are reporting issues with Prime. If you want these then you could consider a Firestick or Roku Stick.
Try phoning 0345 172 0088
Opening Hours can be found here but closed Sundays. https://community.talktalk.co.uk/t5/Articles/How-to-contact-TalkTalk-Broadband/ta-p/2230529#
