Netgem 4K tv box BBC channels go straight to iplayer
RozEd
Message 3 of 3
Can use Wow TV sports channel fine, but Freeview channels are 'not available', apart from BBC which go straight to iPlayer ... driving my husband mad!! Please help x
RozEd
Message 1 of 3
Many thanks, it worked! (until next time maybe?)
Message 2 of 3
This error should have been fixed a few weeks ago.
Try retuning the channels first and then select channel 1. Of it still persists try resetting the box by pressing the button on the left hand side 5 times until the box restarts.
You will though lose any recordings if you use a usb stick and also need to sign into your apps, like Now, again.
Let us know how you get on please.
Anonymous User
