Netgem TV box faulty?
Suzyb36
Message 2 of 2
My TV box every week looses channels.  I retune several times but they don't come back straight away.  It can take a 2 or 3 days before they come back.  The only way I can get them back sooner is to Reset the box, but then I loose all my recordings.  When I've recorded and then play it back it also jumps 5-6 seconds ahead and freezes.  Any ideas what's wrong?
1 REPLY 1
Message 1 of 2
If you connect the aerial direct to the TV and check the channels, do they show any issues, breakup, poor reception etc ?
