Prime video not working on box tried to uninstall reinstall still nothing
Gillc40
Message 3 of 3
My prime video not working on the android box
Message 1 of 3
Hi Gill,
How are you getting on?
Message 2 of 3
Can you log in ok or does this fail?
If its not working and you have done the reinstall, then the only option left is to perform a factory reset from the settings menu.
Hope this works and please let us know how you get on.
