problems with a few apps
dougaldo
Message 8 of 8
My talktalk wifi to my laptop works fine.  For most cases, the apps on my phone work fine.  There are 2 or three apps, however, that seem to buffer and take some considerable time to download.  One example is BBC News.  If I turn off the wifi to my phone or use any other wifi then these apps work as expected.  It appears that it is a specific problem between the talktalk wifi and a few apps on my Android phone.  I have tried (on numerous times) to reboot the wifi and the uninstall and reinstall the affected apps, but it never resolves the problem.  Any Ideas?
7 REPLIES 7
Message 1 of 8
A router is on the way to you.
dougaldo
Message 2 of 8
Okay thanks. I am quite happy to try a new router.
Message 3 of 8
Ok thanks for confirming. Are you happy for us to send a replacement router to see how this compares and to rule this out?
dougaldo
Message 4 of 8
My phone is a Motorola - Moto e13.  The OS is Android Go version 13.
As given before, the phone is fine on any one else's wifi . The phone is fine for most apps using my Talktalk broadband.  It is just afew apps giving the problem - especially BBC news and Emis.
Message 5 of 8
Thanks for trying that. Which mobile do you have and which version of the OS is it running?
dougaldo
Message 6 of 8
I tried your suggestion and I turned the router off for more than 30 minutes (55 in fact!), but it didn't make any difference.  What now?
Chris-TalkTalk
Message 7 of 8
Hi dougaldo,
Can you switch your router off and leave it off for at least 30 minutes, then switch back on and retest. Please let us know if this resolves the problem
