on 11-03-2025 10:46 AM
Rubbish service
on 15-04-2025 08:55 PM
Please start your own topic and the support team can look into this for you.
on 15-04-2025 08:37 PM
When selecting BBC it automatically goes onto the IPlayer live TV. Furthermore, when watching TV on the IPlayer, it constatly goes into buffering. I have writen to you as I read the reply you gave to a similar query. In that case you advised to place the Tv aireal into the TV socket. This I have done and the problem persists
on 11-03-2025 10:49 AM
Connect the aerial direct to the TV and check the BBC channels to see if there is poor reception.
This will often happen if the signal to the BBC channel is poor.
