New 4k tv box recording
Nicfu
Message 4 of 4
Hi I have just upgraded to the new 4k box, is it just me or is it a load of rubbish. You can only record 1 thing at a time that’s if it catches the whole program!!
any advice would be gratefully received
3 REPLIES 3
Message 1 of 4
That's the one that I purchased for my box.
Nicfu
Message 2 of 4
 Hi do you mean one of these?
Message 3 of 4
The box is basically a streaming box with a tuner and limited recording facility as you have found.
This has been a common complaint since it was introduced.
TalkTalk have not supplied a fully recording box for 3 years now.
There are no workarounds to recording. Advice is to buy and aerial splitter and cable to have separate feeds to the box and TV so you can watch a TV channel whilst recording another on the box.
