on 06-01-2025 04:24 PM
Try saying, appears on bottom of t.v. Screen and cannot remove, any answers
on 07-01-2025 07:23 AM
The google assistant can be triggered if you have pressed the microphone button on the remote.
on 06-01-2025 04:57 PM
It looks like a Google Assistant thing. Have a search for it on, er, Google? Other search engines are available.
on 06-01-2025 04:54 PM
Do you mean your TalkTalk box?
If so which box do you have?
Not seen this before.
Have you pressed the microphone button by mistake? Try pressing it. Does the message disappear?
Can you take a photo and upload it please?
