on 25-11-2024 10:13 AM
I have the TT Netgem N7950 recordable TV box.
I use the recording facility frequently especially where the program that I want to watch is not available on catch up. Is there a setting that I can change that determines the start time for a recording? Every time I watch a recording the first few minutes of the program are missing.
on 27-11-2024 10:49 AM
You can of course factory reset the box to start wit a clean setup, but ultimately the recording start and end time rely on a signal from the individual broadcaster. I've seen this before across different devices and suppliers, so it is rarely an issue with the box itself.
on 27-11-2024 10:23 AM
Hi Karl,
on 25-11-2024 10:22 AM
Manual time recordings can not be set. Timed recordings rely on a signal from the broadcast channel to trigger the recording start and end.
