Tv hub recording
Lassiedog
Message 4 of 4
How do I record a programme on my new tv hub using the new remote. I can’t see any button to press.   there was one on the old remote with the box I had before
3 REPLIES 3
Message 1 of 4
This page highlights the features of the Hub.
https://community.talktalk.co.uk/t5/Articles/About-the-TalkTalk-TV-Hub/ta-p/2915720
Message 2 of 4
You can't. The box is a streaming box only.
When you watch a programme using catchup it's added to your watch list for easy access. You can also add programmes you want to watch to this list in advance.
TalkTalk have not supplied recordable boxes for around 4 years now.
If you still have a functioning YouView box you can set both up and continue to record, but you will ned a separate aerial feed to both boxes. This can be achieved by buying a simple splitter and cables from most supermarkets or from a local market electrical stall, where you will probably get advice if you require it.
Divsec
Message 3 of 4
Hi @Lassiedog I'm pretty sure the new TV boxes don't record. The thinking is that streaming through iPlayer and similar is the future.
From the 29th of March our TalkTalk Community will move to peer-to-peer support and the TalkTalk team will no longer be here to support with queries. Don't worry we still have plenty of ways to reach out if you need to speak to TalkTalk directly. For more details check out the link here: How to contact TalkTalk Broadband - Help & Support. 03451720088
