Recording
GBL229
Message 4 of 4
How do i record on my talktalk box those programmes not on demand. When i try i get cant add to my tv as it isnt avail on demand?
3 REPLIES 3
Message 1 of 4
As I said, there is no recording function on the Hub.
I believe you can pause it, but the time is limited to 30-45 mins.
Box info can be found here.
https://community.talktalk.co.uk/t5/Articles/Compare-our-TalkTalk-TV-Boxes/ta-p/2204428
GBL229
Message 2 of 4
Thanks for info I have a hub.   I understand most of it but wondered if I was watching a program that isn’t on demand and had to leave it part way through could I record it from where I left it?
Message 3 of 4
Which box do you have?
The Netgem 4k box requires a usb stick for recording. You need to supply this yourself. A stick up to 256 gb is recommended.
If you have the TV Hub, this does not record.
If you have a 370 Or 372T box, you press the R button on the programme from within the guide. These 2 boxes are old now and TalkTalk have not provided these for over 3 years now.
