Regular issues losing tv channels on tv4k box
blouise
Message 5 of 5
On a very regular basis I lose tv channels from itv onwards on my 4k tv box.  Retune doesn't return them.  Only option seems to be box reset but then I have to re-sign into all my apps.  Happened twice in last week.  A few other posts suggests same issue experienced by others.  Any advice to stop this happening?
4 REPLIES 4
Message 1 of 5
A replacement box is on the way.
blouise
Message 2 of 5
Yes Karl if you think this will resolve the problem. Thsnks
Message 3 of 5
Hi bladonlouise
Would you like to swap out the box and see if that helps.
Message 4 of 5
A reset pressing the button on the left hand side 5 times will usually clear this but as you've tried that, there isn't anything else to try.
You are in the staff's queue for a response.
For a quicker reply can you please ensure you have your personal information up to date in your profile including your TalkTalk landline phone number so your account can be traced. Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
You can also add your account number in the private notes field, which only you and the support staff can view.
Please post back when done.
Thank you
