Rubber on back of remote sticky
plucky
Message 3 of 3
I've noticed that the back of my remote for the TalkTalk TV box has been turning more sticky, I think the coating on the back and sides has degraded for some reason, the top is perfectly fine. I noticed another member had the same issue last year and I was wondering if it is possible to get a replacement?
@Karl-TalkTalk perhaps you can assist as you helped on the other thread? Thanks.
Message 1 of 3
You can clean the back of the remote with a little nail varnish remover or I recently cleaned a remote of mine for an older HiFi with a little hand sanitiser and a cloth, that restored the plastic of the remote.
Message 2 of 3
This box is no longer available.
