Tv remote
Paul166
Message 3 of 3
The guide button on tv hub remote not working
Message 1 of 3
Hi Paul166
did you try resetting the box, did this help ?
Message 2 of 3
I would suggest that you reset the box in case the software has become corrupted.
Resetting the box will download the latest software. If this doesn't work please post back.
Than you.
