TV Hub USB port
JABrunning
Sightseer
Message 3 of 3
Hello.
It appears the new TV Hub doesn't record, so what is the USB port for?
Message 1 of 3
A keyboard or mouse can also be connected.  I've currently got a webcam connected to mine and used it for video calls to phones using Google Meet.
Message 2 of 3
You can use the USB slot to play compatible media (for example photos and home videos) on your TV Hub.
