on 09-04-2023 12:27 PM
I have been in contact via live chat this morning about my TalkTalk tv box problem, which is, I can only get the "no signal" floating graphic on the tv screen. I have tried turning off the box and then back on again, it goes through the set up, but then just to the no signal graphic again. It does not respond to the handset. I have plugged the aerial directly into the TV and there is no problem with the programmes at all.
I have had two attempts at the live chat, the first I got quite a way through with the agent who was going to do some checks on the line to my property and then the chat was disconnected, I tried again and got through to the second agent and only managed to give him my details and the fault, but the chat was disconnected again.
As the aerial signal is not the problem I can only assume that the box is faulty and if so, how do I get a replacement.
Anyone can help please??
on 22-05-2023 08:21 AM
No Problem 🙂
on 22-05-2023 08:12 AM
Hello Karl, received the new 4k box. Not sure if I'll be keeping it though. It's not as user friendly as the old box, plus the fact that the recording capability is severely limited means that it doesn't really fulfill my needs. The reason for the recording for me, is the ability to record two channels at a time and watch a live channel at the same time, so that I don't have to waste time watching adverts that I have no interest in. All the adverts that you have to endure when streaming is not for me. I'll give it another month, but I think it will have to go back. Thanks for your help with this.
Jimbly
on 14-05-2023 09:00 AM
Thanks for that Keith. I managed to get it sorted on another number.
Jimbly
on 12-05-2023 01:23 PM
It is 0345 1725157.
on 12-05-2023 01:22 PM
Hello Karl, could you let me have the Customer Loyalty Team phone number please.
Cheers.
Jimbly.
on 09-05-2023 07:41 AM
OK, they will not need to renew the contract, but they can discuss adding TalkTalk entertainment for you at £5 per month. This replaces the former TV charge and covers the rental of the new 4K TV Box.
on 08-05-2023 08:48 PM
Hello Karl, thanks for that. I renewed my contract last month.
Cheers.
jimbly.
on 08-05-2023 09:20 AM
If you give our Customer Loyalty Teams a call and request one of the new 4K TV boxes, they can discuss this with you. They will add TalkTalk entertainment to your package and depending on how long is left on your contract, they may discuss renewal with you.
on 06-05-2023 05:33 PM
Hello Karl, still not working properly, it's doing my head in! How do I go about getting the replacement 4k box?
Cheers
Jimbly
on 21-04-2023 06:51 AM
No Problem 🙂
on 20-04-2023 07:17 PM
Hello Karl,
Thanks for that, as soon as it lets me get into settings, I will try it and see how it goes. If I can't I'll get back to you.
Cheers.
Jimbly
on 20-04-2023 07:13 PM
Thanks for that Karl, when it let's me get into settings, I will try that and see if it's any better.
Cheers.
Jimbly
on 19-04-2023 04:06 PM
It is possible the box is starting to fail. You can try a full factory reset from the settings menu and see if that changes anything, but if not, then the box will have failed.
As we do not provide these box models any more, then it cannot be repaired or replaced.
You may be eligible for one of the new 4K TV boxes.
on 19-04-2023 04:02 PM
Hello Karl, it's gone from bad to unusable now. Can't see any channels now, it's either saying no signal with a black screen or very occasionally a few coloured pixels. So I can't watch live TV and it continually fails to record because of this. With the aerial connected direct to the TV there is no problem with the reception at all.
Is the box faulty/breaking down?
Any help please.
Cheers.
on 10-04-2023 12:36 PM
Ok, Thanks for letting me know.
on 10-04-2023 12:26 PM
Checked tht Karl, but it still works the same as it did with it switched off. No signal on tv when switched to aerial input.
Which isn't a problem, if I get a box problem I'll just switch the aerial cable to tv direct.
on 10-04-2023 12:16 PM
The antenna out function will allow the aerial signal to pass through to you TV so you can use the TV freview option with the aerial signal.
If the no signal message appears on screen, first thing to check is that the HDMI cable is seated correctly, the correct HDMI (source) channel has been selected, and see if you can see any youview menus when pressing any keys on the remote.
on 10-04-2023 12:13 PM
Right I've done that. What is the function of this.
Just to say, that the box would not get past the no signal screen at all yesterday, despite trying numerous times between 8am and 11pm, but this morning the came on as normal and so far is working normally.
on 10-04-2023 11:47 AM
OK, first question, when you select the correct source channel on your TV, do you see the youview menu when pressing the remote ?
To locate the Antenna Out, go to Settings, then picture and quality, and Antenna Out should be the bottom option.
on 10-04-2023 11:43 AM
YouView > Settings > Picture & Sound > Antenna out
Turn this on.
