TV screen frozen and no sound
Jacky9
Message 3 of 3
I have a fairly new TV hub box which has worked fine but today the TV screen picture is frozen and there is no sound.  Help please.
Message 1 of 3
Hi Jacky,
How are you getting on?
Message 2 of 3
I suggest you reset the box to see if this improves the situation, but it may be the weather that is playing havoc with signals in some regions
To try a reset follow the instructions here.
https://community.talktalk.co.uk/t5/Articles/TV-Box-Maintenance-Reset/ta-p/1429347
Let us know how you get on.
