Talk talk tv box
Marks4
Message 4 of 4
Hi,I have looked at having talk talk tv.but when my area got checked for signal strength,said there is no free view set up in my area.even though my freeview works on my tv.Was wondering if anyone else had this problem and what they did
3 REPLIES 3
Message 1 of 4
Hi Marks4
Did the advice from my colleagues help ?
Message 2 of 4
Was this check via the TalkTalk website? Very strange. Have you checked the Freeview site for coverage?
If you are sure you want to rent a box then your best option if the website says no, is to phone.
Try phoning 0345 172 0088
Opening Hours can be found here - https://community.talktalk.co.uk/t5/Articles/How-to-contact-TalkTalk-Broadband/ta-p/2230529#
Other alternatives if can't get a box from TalkTalk are to purchase your own box. If you want one that records you could look at the BT (EE) pro box from secondary retailers like CeX or the new Manhatten Box.
Or if you are after just  the apps as your TV gets Freeview, something like an Amazon Firestick might suit.
Message 3 of 4
Well, I am a wee bit puzzled as to how Freeview works on your TV without a signal? Unless you are not using terrestrial channels via an aerial and rely on Internet channels alone? All TVs are Freeview capable.
