Tv box refuses to pause, rewind, fast forward or record
62colin
Message 6 of 6
My box has never worked since I received it, what can I do to address?
5 REPLIES 5
Message 1 of 6
If the USB stick has been correctly formatted but is not allowing you to record, I would test another USB stick.   Not all USB devices are equal, some of the cheaper branded ones can have issues.  A 256GB stick is usually adequate for most recordings.
Message 2 of 6
Ps, please complete your profile as requested so staff can trace your account.
Thank you
Message 3 of 6
1tb have been reported to have issues, especially if bought from ebay or third party sellers elsewhere. These are sold as 1tb and although they register as such, they are often smaller capacity that don't format correctly as the capacity does not match that that is expected.
I use a 256mb myself and purchased from a well known supermarket.
Unless your usb works, you will not be able to record, rewind or fast forward.
To get the rewind to work on live TV, you must pause live TV first and then press play. You will be able to rewind to this pause point when required.
A recorded programme should let you ff and rewind.
Hope this helps.
62colin
Message 4 of 6
Thanks for the reply.
it’s a 4k box and I’ve formatted a 1tb usb in it but nothing works other than getting the standard tv picture!
Message 5 of 6
Can you confirm which box you have and how long you have had it as recordable boxes have not been supplied for about 2 years now?
If a YouView box, it may be that you have a remote with a record button. The remotes are the same for all boxes so it will not work if your box has no hard drive.
As to rewind and ff, these will only work on live TV if you have paused or previously rewound the current programme. Changing channels resets this function.
If you have a 4K box you need a usb stick to record and use live TV rewind. Search for Netgem 4k manual for a better explanation of how this box works.
If you have a recordable YouView box, Have you tried a soft reset? To do this hold the power button on the front for around 10 seconds and the box should restart. Alternatively, you can turn off from the back and power back on.
If this doesn’t work then have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If all else fails then try a full factory reset from the settings menu. You will lose your recordings but you may be asked to do this before the Support Staff look at other alternatives.
Please note that if you are eligible for a new box, TalkTalk now only supply non-recordable ones., So it's best to try all alternatives if recording is important to you.
Hope it works but if not then please let us know as you are in the staff's queue for a response.
For a quicker reply can you please ensure you have your personal information up to date in your profile including your TalkTalk landline phone number so your account can be traced. Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
Thank you
