USB Drive
harley0459
Message 3 of 3
I have attached a USB drive to my Talktalk TV and it had recognised it and it has been formatted.
Using Cx File Explorer which sees the USB Drive but when I try to access it a pop up window appears that Permission Settings, Use This Folder. When I click on OK the next view is You don't have an app that can do this.
I'm not sure what app it could be and I can't find anything in settings.
Message 1 of 3
Should add, if a 4k box, go to settings and find format usb to use with the box.
Message 2 of 3
If you have a 4k box, the box should go the formatting for use with the box.
If it's a TV Hub, the usb is for playback of media, music, photos etc, and if there is no media it can't find an app for playback.
Anonymous User
