Recordings won’t work
Leash11
Message 6 of 6
For the last week my recordings won’t work. I set things to record and they disappear. I do the same again and it happens again. Nothing is recording and no planned recordings are saving even though that show as scheduled initially.
5 REPLIES 5
Message 1 of 6
@Voyagersprit1
Please as requested, start your own thread and answer the questions raised to others, as you will not receive help posting on other customer's threads.
Thank you.
Voyagersprit1
Message 2 of 6
Same as me with 4k box...
Message 3 of 6
If failing to record, you can try a full reset, by pressing the button at the side of the box 5 times.
This will however mean the USB stick will have to be initialised again and any current content removed.
Leash11
Message 4 of 6
The 4k box.
Thank you.
Message 5 of 6
What model of TV Box do you have ?
