Freeview guide
martintalk
Message 2 of 2
I have a Netgem TV box. The Freeview guide does not include itv channels, channel 4 or 5. BBC channels are ok. If I type in 103 to 105 where these channels used to be they appear and can be watched as normal but they don't appear on the guide. I have retuned many times with no change. It's infuriating. I don't want to reset the box unless I have to because I will lose all my recordings. I have read other threads that report the same thing.
1 REPLY 1
Message 1 of 2
Try powering off the box at the mains for 20 minutes and see if this helps.
If this keeps failing then a reset of the box may be required.
