Where is my sSID nimbet
Danie4
Message 3 of 3
Where is my SSID number I need this to connect internet to my tv
Message 1 of 3
As fr8ys says, the SSID is just the Wi-Fi name from your router.   This can usually be found on the back of most routers.  If you have the Wi-Fi HUB it is on the card at the back.
Message 2 of 3
In simple terms this is your network name. The same as you'd use to connect any device to your router via WiFi.
Unless you have changed it, it's on the reverse of your router.
