set top box is permanently zoomed
philrowe
Message 4 of 4
my set top box is permanently zoomed so I can't see the entire screen. I can't access the settings menu
3 REPLIES 3
Message 1 of 4
The earlier remote had the zoom button at the bottom, the later remotes had the zoom button at the top, if you press this a couple of times, does it reset the zoom rate to normal ?
philrowe
Message 2 of 4
Huawei 372T
Message 3 of 4
What TV Box do you have ?
