on 13-12-2024 01:37 PM
guide says that these channels are live, but I cant access them.
on 13-12-2024 01:45 PM
Connect your aerial direct to your TV and check if this can receive those channels. If not, they may not be available in your region.
You can also check what channels are available at https://www.freeview.co.uk/freeview-channel-checker
