Your Account
Charged for engineer visit when fault with TalkTalk router
Naomi04
Message 6 of 6
Hello, we have exactly the same problem as outlined here:
https://community.talktalk.co.uk/t5/Billing/Charged-65-Engineer-Visit-charge-when-Engineer-diagnosed...
we are being charged an extra £75 this month because of a problem that was diagnosed by the engineer as a faulty TalkTalk router. We were sent a new router because of this, and have experienced no problems since.
we have been a customer since September 2018 which is when we were given the router
this is our third renewal, we have not been sent a new router at all in the past 5 years despite the renewals.
as outlined in the previous case, none of the sections in the Ts&Cs apply to our case either, the fault was with the router and not within our home.
Taking this section by section:-
"We'll charge you if the Openreach engineer was unable to find a fault with your service" - He did find a fault with the service - it was with the Talktalk supplied router which he arranged to have replaced by Talktalk and which duly arrived two days later.
"or the fault was found to be related to a condition in your property or garden." - No fault found with property or garden - the fault was with the Talktalk supplied router, which Talktalk themselves replaced.
"Any faults related to your main phone socket may also incur a charge, as will issues caused by any personal devices connected to your line." - No issues were found with the main phone socket, nor were there any issues caused by any personal devices connected to our line. - this issue was with the Talktalk router.
"You won’t be charged for faults caused by Openreach equipment." - but I am being charged for faults caused by Talktalk equipment.
Obviously, for the reasons given above,  I disagree with the charge being added to our bill.
Can someone at Talktalk please look into this for me so that it can be resolved without having to go through the complaints route?
5 REPLIES 5
Message 1 of 6
Hi @Flemingston
I'm sorry to hear this. Please can you create your own topic and we'd be happy to look into this for you.
Flemingston
Message 2 of 6
I have just had the same charge. I had a call blocker fitted to stop the endless stream of crap calls the phone company can't stop and it caused a fault. So I destroyed it and don't answer any calls I am not expecting from anyone. That is all I can do. There needs to be a system where nobody can call you without an access code you have previously given them. that would end all of these junk calls forever. That seems beyond today's "wonder" technology at the moment.
Message 3 of 6
@Sony123,
These charges are specific to the situation.
Staff need you to start your own thread.
Please return to the message board and click on start a topic.
As mentioned in my reply to your thread from last month, staff are not here at weekends:
https://community.talktalk.co.uk/t5/Broadband/My-broadbsnd-wont-work/td-p/3024835
You didn't follow up there. Staff might have been able to run tests to make sure that a visit from an engineer might not be necessary.
You can keep track of previous posts in the Activity area of your profile.
It's helpful if you do complete your customer profile for staff to help you in these situations.
Go via your avatar; settings....drop down menu: Personal Information. SAVE CHANGES.
Sony123
Message 4 of 6
Hi  did yoh get this sorted
 They are trying to charge me £75 too.  My router is fine. It seams there was an external fault that corrected itself. The engineer said the same
Arne-TalkTalk
Message 5 of 6
Hi @Naomi04
I can help with this I first need to confirm some security questions
I have sent you a PM on the community
