Your Account
Set up and connection
Nellyrob6
Message 4 of 4
I was just speaking to Ameen and got cut off.
I have been a new customer of yours for 2 months, I was with Virgin who say I still owe them for the past 2 months.
You connected me ages ago, so I'm confused as to why I would have to pay 2 service providers?
Your help would be appreciated
3 REPLIES 3
Gliwmaeden2
Message 1 of 4
If it were the reverse, and you were leaving Talktalk for Virgin, @Nellyrob6, the instructions here are that you can't just do a One Touch Switch but need to speak to the previous provider.
I would expect the same to apply leaving Virgin as it's not on the integrated Openreach system.
A friendly AI result suggests the same:
Message 2 of 4
Did you give notice to Virgin?
Did you sign up with TalkTalk under the switch procedure?
Have you spoken to Virgin and asked them why they are still charging you when you left 2 months ago?
What did they say?
Message 3 of 4
Did you use the One Touch Switch service? Otherwise, your issue would seem to be best taken up directly with Virgin.
