on 29-01-2025 11:54 AM
Why can't I view my phone call list so I can check calls?
on 29-01-2025 02:10 PM
Hi 13911
Do you mean the itemized calls on your bill? if you select view the bill, and scroll down, you will see
This will show you the calls.
Hope that helps.
