After re-boot of router speed is good (36-40 Mbps), but drops to <2 after a few hours
MistleyTowers
Message 6 of 6
the signal coming into my flat is constant at around 36-40 MBps.
However, after a few hours the speed drops to less than 2 Mbps. Both hard-wired (Cat 5 cable) and WiFi connections are affected.
Looking at other posts on the forum, I can see that this a known problem.
The issue appears to be with the router, replacement of which solves the problem.
This beiung so, could you please send me a replacement router.
PS. Apologies for the confusion caused by my previously using an old profile I had completely forgotten about.
5 REPLIES 5
Message 1 of 6
Hi @MistleyTowers
Have you received the replacement router? Is everything working ok now?
Message 2 of 6
How has your connection been over the last 48hrs?
Message 3 of 6
Good morning,
No problem. We'll check back in with you in a few days to see how your connection has been with the replacement router.
Message 4 of 6
Thank you for your patience and your help.
And, of course, for sending the router.
Mistley Towers
Message 5 of 6
Hi @MistleyTowers
Thank you for creating a new topic.
I have ordered a replacement router, please allow 24-48hrs for this to arrive.
