B
Today18
Message 41 of 41
All of a sudden my broadband download speed has virtually stopped. Spoke to technical checked said up to router fine suggested pay for engineer £75 to come in or look at upgrade package to increase speeds. I have been with TalkTalk for some 20 years plus and I’m little confused as my speeds have been up to now so I either have a problem or I need to upgrade, bit of a difference. Sounds like they have throttled my speed to get me to up my package. Any thoughts
40 REPLIES 40
Message 21 of 41
Hi Today18
Ok no problem. @KeithFrench  provides really good advice on improving wireless performance. Would you be able to help please Keith?
KeithFrench is one of our valued Community Stars and can help with a range of issues related to wireless and networking. At times he may ask you to send him test results via a Private Message to help analyse/diagnose an issue.  Although Keith does not work for TalkTalk, he very kindly shares his time and knowledge to help with others.
 If you need further help or, if we need to take any details such as personal information about your account like phone numbers, account numbers etc.  one of the TalkTalk team will jump in and help out.
Message 22 of 41
No I don’t have the facility to hard wire as I have a iPad. No laptop or computer.
Message 23 of 41
Message 24 of 41
Hi @Debbie-TalkTalk
No, I have not seen that, but without looking into this thread if these are wireless devices, that might be down to WiFi reception issues. Certainly, the speeds reported by the devices do seem to be wrong.
Message 25 of 41
Thanks @Today18
@KeithFrench  when you ran some speed tests were any of your devices showing "might be experiencing speed issues"
Message 26 of 41
See attached.
Message 27 of 41
Hi Today18
Would you be able to post a screen shot here? (please remove any personal details such as phone number etc)
Message 28 of 41
Yes I have seen that but it doesn’t give me speed to my device just says you are experiencing speed issues where the old way it gave me the router speed and speed to my device so instantly I could see I was having problems.
So how do I get the speed to my device to make sure it is not causing a problem with speeds.
Message 29 of 41
Hi Today18
One of our Community Stars has run the speed tests:
Running it from My Connection defaults to speed to the router, then if you click the link top right "Speed to devices"
Message 30 of 41
Hi Today18
That's great, thanks for letting me know.
I'm just checking about the speed tester now and I will post back as soon as I have further information.
Message 31 of 41
yes router has come and I have set up.
The speed is better and I did some speed testing. And users are not complaining as before so hopefully sorted.
  • Over the weekend the speed checker on talktalk has changed and with the change it gives me the router speed but I cannot see speed to my device. I only get that some devices might be experiencing speed problems. Is there a recommendation on how to use it or is there another site I can use.
Are you aware of the change?
regards
Message 32 of 41
Message 33 of 41
Hi Today18
Ahh you're welcome 🙂
I will check in again with you once you have received the router to make sure everything is working ok.
Message 34 of 41
Thank you much appreciated
Message 35 of 41
Hi Today18
Thanks for updating your Community Profile 🙂
Let us know how the connection/speed compares with this router.
Thanks again.
Message 36 of 41
updated profile
Message 37 of 41
Hi Today18
I can send you a replacement router for testing. Please can you add your name and TalkTalk landline number to your Community Profile, I can then send out the router.
Message 38 of 41
That would great
Message 39 of 41
I asked to whether a new router would help as I’m on old router Huawei hg 633.
As usual charge. I don’t understand why speed has gone so slow, and why if it a problem why also is my upload speed still the same has never changed. I have spoken to technical and offered to send engineer or upgrade package. Your help would be much appreciated
Message 40 of 41
TalkTalk do not throttle, so that is definitely not the issue. The support team here will gladly look into your broadband performance and guide you accordingly.
