Broadband half guaranteed speed
Sunnyspirals
Message 42 of 42
I have fibre 35 which has a guaranteed speed of over 30mb/s. We actually get a maximum of 15mb/s. The speed to the router is 15mb/s but we get less than that on wireless gadgets.
I spent a long time on the web chat three days ago running through diagnostic checks. I was told that the speed should increase within 3 days. The speed has not and is still running at less than 15mb/s.
What do I do next to get the speed I should be getting?
41 REPLIES 41
Skynet_TX
Message 41 of 42
Hi @Sunnyspirals,
It would be worth going to the Service Centre to run a connection test on your line (although the web chat team should have already checked this), this will indicate if there is currently a fault affecting your service. You can also access this from the ‘My Account’ site.
If your master phone socket has a test socket then you could also try the router in there, that would then eliminate any of the phone wiring in your home as being a possible cause of the problem (although you may need to leave the router connected at the test socket for 72+ hours before you would start to see a speed increase if this was the cause of the problem).
Then they will hopefully be able to respond to this post within a few working days.
