DG8041W keeps resetting with kernel panic
jmmb20201
Message 5 of 5
Hi TalkTalk,
Like many other users here, my TalkTalk DG8041W (v1.0.5t) router keeps crashing with kernel panics and rebooting, and it's happening increasingly, now every hour.  This is incredibly bad for me as I keep getting dropped off my meetings. I need reliable service.
I have tried the support chat but the agent was not equipped to deal with the issue.
I have seen that other users here have had similar issues, which you have solved by pushing out a firmware update (v1.0.6):
https://community.talktalk.co.uk/t5/Broadband/DG8041w-kernel-panic/m-p/2850168#M829823
https://community.talktalk.co.uk/t5/Fibre/DG8041W-restarts-with-Kernel-Panic-error/td-p/2772076
https://community.talktalk.co.uk/t5/Fibre/DG8041W-Kernel-panic/td-p/2789784
etc.
I have attached the user logs below. If you could help fix this as soon as possible, I would be incredibly grateful.
2022-01-25 21:12:03 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,ConnectionRequestUsername:userid,ConnectionRequestPassword:-
2022-01-25 21:12:03 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,PeriodicInformEnable:1,PeriodicInformInterval:86400,PeriodicInformTime:2022-01-25T21:12:03.186Z
2022-01-25 21:12:04 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,ConnectionRequestUsername:userid,ConnectionRequestPassword:-
2022-01-25 21:12:04 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,PeriodicInformEnable:1,PeriodicInformInterval:86400,PeriodicInformTime:2022-01-25T21:12:04.195Z
2022-01-25 21:12:05 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,ConnectionRequestUsername:userid,ConnectionRequestPassword:-
2022-01-25 21:12:05 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,PeriodicInformEnable:1,PeriodicInformInterval:86400,PeriodicInformTime:2022-01-25T21:12:05.153Z
2022-01-26 21:12:06 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,ConnectionRequestUsername:userid,ConnectionRequestPassword:-
2022-01-26 21:12:06 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,PeriodicInformEnable:1,PeriodicInformInterval:86400,PeriodicInformTime:2022-01-26T21:12:06.364Z
2022-01-26 21:12:07 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,ConnectionRequestUsername:userid,ConnectionRequestPassword:-
2022-01-26 21:12:07 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,PeriodicInformEnable:1,PeriodicInformInterval:86400,PeriodicInformTime:2022-01-26T21:12:07.353Z
2022-01-26 21:12:08 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,ConnectionRequestUsername:userid,ConnectionRequestPassword:-
2022-01-26 21:12:08 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,PeriodicInformEnable:1,PeriodicInformInterval:86400,PeriodicInformTime:2022-01-26T21:12:08.743Z
2022-01-26 21:12:09 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,ConnectionRequestUsername:userid,ConnectionRequestPassword:-
2022-01-26 21:12:09 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,PeriodicInformEnable:1,PeriodicInformInterval:86400,PeriodicInformTime:2022-01-26T21:12:09.290Z
1981-01-01 00:00:10 [Error][Alarm-Log] AlarmID:104001,AlarmLevel:Error,Device reset. Cause: System reset after being powered on, Terminal:OTHER
2022-01-26 21:22:07 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2022-01-26 21:22:07+00:00], uptime is [50s].
2022-01-26 21:22:19 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,ConnectionRequestUsername:userid,ConnectionRequestPassword:-
2022-01-26 21:22:29 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,PeriodicInformEnable:1,PeriodicInformInterval:300,PeriodicInformTime:2022-01-26T21:22:29.175Z
2022-01-26 21:27:30 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,ConnectionRequestUsername:userid,ConnectionRequestPassword:-
2022-01-26 21:27:30 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,PeriodicInformEnable:1,PeriodicInformInterval:86400,PeriodicInformTime:2022-01-26T21:27:30.419Z
2022-01-26 21:27:31 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,ConnectionRequestUsername:userid,ConnectionRequestPassword:-
2022-01-26 21:27:31 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,PeriodicInformEnable:1,PeriodicInformInterval:86400,PeriodicInformTime:2022-01-26T21:27:31.623Z
2022-01-26 21:27:32 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,ConnectionRequestUsername:userid,ConnectionRequestPassword:-
2022-01-26 21:27:32 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,PeriodicInformEnable:1,PeriodicInformInterval:86400,PeriodicInformTime:2022-01-26T21:27:32.300Z
1981-01-01 00:00:09 [Error][Alarm-Log] AlarmID:104001,AlarmLevel:Error,Device reset. Cause: System reset due to kernel panic, Terminal:OTHER
2022-01-27 04:19:34 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2022-01-27 04:19:34+00:00], uptime is [51s].
2022-01-27 04:19:46 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,ConnectionRequestUsername:userid,ConnectionRequestPassword:-
2022-01-27 04:19:55 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,PeriodicInformEnable:1,PeriodicInformInterval:300,PeriodicInformTime:2022-01-27T04:19:54.984Z
2022-01-27 04:24:54 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,ConnectionRequestUsername:userid,ConnectionRequestPassword:-
2022-01-27 04:24:54 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,PeriodicInformEnable:1,PeriodicInformInterval:86400,PeriodicInformTime:2022-01-27T04:24:54.521Z
1981-01-01 00:00:10 [Error][Alarm-Log] AlarmID:104001,AlarmLevel:Error,Device reset. Cause: System reset due to kernel panic, Terminal:OTHER
2022-01-27 12:23:17 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2022-01-27 12:23:16+00:00], uptime is [50s].
2022-01-27 12:23:29 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,ConnectionRequestUsername:userid,ConnectionRequestPassword:-
2022-01-27 12:23:39 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,PeriodicInformEnable:1,PeriodicInformInterval:300,PeriodicInformTime:2022-01-27T12:23:39.655Z
2022-01-27 12:28:39 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,ConnectionRequestUsername:userid,ConnectionRequestPassword:-
2022-01-27 12:28:39 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,PeriodicInformEnable:1,PeriodicInformInterval:86400,PeriodicInformTime:2022-01-27T12:28:39.956Z
2022-01-27 13:00:48 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2022-01-27 13:00:48+00:00], uptime is [51s].
2022-01-27 13:01:01 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,ConnectionRequestUsername:userid,ConnectionRequestPassword:-
2022-01-27 13:01:11 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,PeriodicInformEnable:1,PeriodicInformInterval:300,PeriodicInformTime:2022-01-27T13:01:11.614Z
2022-01-27 13:06:11 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,ConnectionRequestUsername:userid,ConnectionRequestPassword:-
2022-01-27 13:06:11 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,PeriodicInformEnable:1,PeriodicInformInterval:86400,PeriodicInformTime:2022-01-27T13:06:11.677Z
2022-01-27 14:42:30 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2022-01-27 14:42:30+00:00], uptime is [50s].
2022-01-27 14:42:43 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,ConnectionRequestUsername:userid,ConnectionRequestPassword:-
2022-01-27 14:42:52 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,PeriodicInformEnable:1,PeriodicInformInterval:300,PeriodicInformTime:2022-01-27T14:42:52.611Z
2022-01-27 14:43:28 [Critical][Config-Log] Terminal:WEB(192.168.1.16),Result:Success,Type:Login,Username:admin
4 REPLIES 4
Message 1 of 5
Thank you so much @Karl-TalkTalk ! I hope it works!
Message 2 of 5
No Problem 🙂
jmmb20201
Message 3 of 5
Message 4 of 5
I've updated the firmware, this should resolve the Kernel Panic issue you are seeing.
