on 28-12-2023 02:06 PM
I am having broadband issues for over 6 weeks with a speed of 3mbps against contract of 64mbps I have had engineers from both openreach and talktalk both unable to fix the issue It seems that 64mbps is reaching the router from the line but only 3mbps is the available from the router On a speedcheck it shows initially a download speed of around 20mbps but the the rapidly within seconds reduces to around 3mbps but strangely shows upload of 10mbps!
Can anyone suggest where I go or offer ant solutions Many thanks
on 04-01-2024 07:43 AM
Hi Simonh23
Do you still need help with this?
on 02-01-2024 08:42 AM
Hi Simonh23
Your line is showing in sync at just under 60mb. Please can you power down the router for a full 30 minutes and then run another speed test?
on 29-12-2023 05:42 PM
Staff will be back on Tuesday to follow up, @Simonh23.
on 29-12-2023 05:18 PM
Profile updated with details
on 29-12-2023 08:31 AM
Hi Simonh23
Please can you add your name and TalkTalk landline number to your Community Profile, I can then take a look at this for you.
on 28-12-2023 06:29 PM
Wired connectors
on 28-12-2023 06:11 PM
It is the same with wi-fi or ethernet
on 28-12-2023 02:48 PM
Is this via wireless connections or wired (Ethernet) connections from your devices?
