on 07-04-2025 03:35 PM
I'm unable to disable HomeSafe in my Security Settings page. I can enable/disable the other features such as Scam Protection and KidSafe but HomeSafe has no such controls.
Any tips on how to disable HomeSafe?
on 07-04-2025 05:03 PM
Hi nambuso,
The guidance at the link you provided does not work.
It says to turn off HomeSafe in the Security Settings; I do not have this option. There are no On/Off options for HomeSafe.
on 07-04-2025 04:16 PM
Hi there sab5106. Please refer to the below link to know more about home safe. Thanks
How to turn off homesafe - TalkTalk Help & Support
